father04co
Eibach Pro-Alignment Camber/Toe Arms kit for Dodge Neon 2000-2005, Plus/Minus 3.5 degrees part#5.67210
This fit a Dodge Neon 2000 to 2005 and a Plymouth Neon 2000 to 2001.
Part Number; 567210k
-Precision alignment camber arm kit for maximum performance
-Prevents uneven tire wear
-Wider range of camber adjustment-suitable for street or track tuning
-One-year warranty
-Necessity for the serious performance tuner with high speed stability
-Comes with instructions
-Product Description
After the installation of either an Eibach Pro-Kit, Sportline spring kit or Pro-Street, R1, R2 coil-over kit, a vehicle's alignment should always be checked. Once a vehicle is lowered, wheel camber may become excessively negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in compromised handling and accelerated tire wear. Eibach offers a complete range of Pro-Alignment kits, which provide a simple, affordable solution to correct excessive negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications, but they also allow an experienced chassis tuner to utilize the increased adjustment range to "dial-in" a performance-oriented alignment that uses negative camber to maximize a chassis' true potential. With correct alignment, turn-in becomes more precise and handling becomes gratifyingly crisp and predictable.
Je parle francais!
45$
-One-year warranty
Je parle francais!
45$
