MildSeven
Hi Guys,
Bought this car in January from a guy in Toronto, I imported it to Montreal, passed inspection (the HARD part). Changed the wheels and made a few repairs.
Repaired items since purchase:
- Leaky Differential (changed all seals, output seals + gasket)
- Sloppy shifter (shifter mounts)
- Transmission output shaft seal + gear selector rod seal
- Drivers Engine Mount
- Both Front Wheel Bearings
- Horn + turn-signal indicators
Purchased Parts
- 15" BBS RMs (15x7front + 15x8rear) with new Toyo 195/45/15
- Rear Strut bar with battery perch
- Euro Turn signals
Still Need attention
- Hole through driver side floor (was patched up to pass inspection) but ideally I wanted to cut it out and weld in a piece
- Little rust on driver door, driver rear fender
- Little rust bubble on passenger door
- Gas smell in trunk (common '02 issue)
- Door seal + Truck seal
- odometer doesn't work
- Paint is old
---> more detailed details below photos:
Current photo:
details lifted from previous seller.
Original listing (with old wheels, not available)
http://www.maxbimmer.com/forums/showthread.php?t=148062
$8,499 serious buyers only, (i'm losing money on the sale)
car located in Dorval, I'll be un-plating it soon for winter and might keep it if no one picks-it up soon... i'm torn.
Purchased Parts
- Euro Turn signals
- Paint is old
Current photo:
The engine was swapped in 2008. A Getrag 240 5-speed from an E21 320is was swapped in at the same time. The car's 3.9:1 open differential is original. Basic specs:
- 1969 M10 block w/ 121ti head
- Crane ignition
- Ireland 292 cam
- 10:1 compression ratio
- E12 valves w/ 1800TiSA valve springs
- mechanical timing chain tensioner
- dual Weber 45 DCOE carbs on Warnford manifold
- 2000ti-style airbox
- Ireland step header
- Ireland polyurethane motor mounts (rear mount needs to be replaced)
- E30 M3 starter
- Electric aux fan
- upgraded fuel system with FPR and Bavaria pump
Body: Verona Red 1976 shell, de-bumpered, new paint (2006) below beltline, battery relocated to trunk
Engine: Rebuilt 1969 M10 w/ 121ti head, Ireland 292 cam, Weber 45 DCOE carbs, vintage airbox, Ireland step header, E30 M3 starter
Transmission: 5-speed from E21 320i
Suspension: Custom front with shortened and bent tii struts, MK1 VW Rabbit Bilstein Sport strut inserts, adjustable coilover perches, camber plates, 19mm front sway
Brakes: Aardvarc Racing BBK (tii version)
Interior: Restored E21 Recaros upgraded with adjustable lumbar support (driver only), new centre console, Moto-Lita wheel, MiG cockpit clock, rare JDM Panasonic stereo w/ frequency shifter, Focal speakers in custom footwell pods, Focal amp, carpeted rear seat delete
- It has some typical 2002 issues (odo not working, fuel smell in trunk) but no game enders.
- I've only got an extra original shift knob, original instrument cluster
- The carbs are tuned, the fuel system is new and the cooling system is in great shape.
