Swap came out of an 04' GTI VR6 24v which was in running order when removed @ 53xxx documented kms.
I intended to use this transmission on my personal corrado, as such the mk4 specific mount was taken off and sold (block at the top of the second to last picture).
This transmission is the much preferred "enclosed" version, meaning that the casing looks like this on the drivers side, and does not have a plastic cap like below.
The gearbox is cleaner then the one pictured (which had 141k kms), as you can imagine with almost 1/3 of the mileage.
This is perfect to use to replace your broken O2M or for your mk2/mk3/corrado/passat guys that want a mint 6 speed trans for your conversions.
Please see my other thread containing the associated parts that were bought for the swap:
Swap includes:
- Axles (will have to confirm if OEM)
- Transmission w/ pigtails for reverse, speed sensor and starter
- Clutch Slave line
- Clutch/PP/FW
- Shifter box/cables/filler material
- Power Steering line
- Motor > Transmission "Gasket"
- All Hardware
Pictures:
Price: SOLD
Located in Montreal, QC.
Swap includes:
- Clutch Slave line
- Clutch/PP/FW
- All Hardware
Pictures:
Price: SOLD
