okok
Shop Representative
I am selling a HP Probook 640 G1 laptop, with complete bmw software installed.
Included is the New Godiag V600-BM VCI interface. I have sold several of these, and everyone finds it to work better than the OE ICOM vci's.
Selling the complete turn key setup for $650. i dont often login to MR. please email me at owen@kingsland.one
1.Comes with ISTA-D, ISTA-P, Tool32, For BMW Coding, ISPI, INPA, E-SYS, WINKFP, NCS-Expert Tool, and you can directly run them.
2.Compatible Protocol: J2534, CAN-FD, DOIP, D-CAN, ISO14230, ISO15765, IFH, K-lineGODIAG V600 stand-out features:
Contained with dedicated For BMW software (same as ICOM, ICOM A2 / A3 / NEXT etc, no need to install any driver.)
1) ISTA-D: used to read / erase fault codes, read the data flow, maintenance guidance, circuit diagram, wiring diagram and directly upgrade & program new models. It will activate the ignition switch without keys during diagnosis.
2). ISTA-P: an off-line programming and coding software system, including the latest database for programming E, F, G, K, I series models
3). Engineer programming & coding software for F series vehicles
4). WINKFP: engineer programming software for E series vehicles.
5). NCS-Expert Tool: engineer programming software for E series vehicles.
6). INPA: engineering diagnostic software for E series vehicles.
7). Tool32: engineer command execution software for E series vehicles.
8). For BMW Coding Tool: WINKFP NCS auxiliary software for importing engineer data for E series vehicles.
GODIAG V600-BM Functions
1. Can perform vehicle intelligent diagnosis, all-system all-function fast diagnosis; can read & clear fault codes, read data stream, actuation test etc.
2. ECU programming and calibration. Fully compatible with official diagnostic software
3. Multi-task diagnosis: based on the efficient architecture design of diagnosis service software
4. Diagnostic feedback: support one-key upload the device logs. If you encounter exceptional vehicle and abnormal function, you are allowed to report the problem to the manufacturer, then the technicians will track and handle your problem.
GODIAG V600-BM Features
1. With the size of about 108 x 52 x 27 mm, the pocket device is more portable
2. Brand new industrial design, the shell is made of solid and stain-resistant material, it is more suitable for the automobile maintenance environment.
3. Support WiFi wireless connection, high-speed transmission, long-distance transmission, stable signal and strong anti-interference; WiFi can be set as STA or AP mode at the same time, making users work in comfortable indoor environment.
4. Support wired Ethernet connection,can freely switch between 2 modesWAN / LAN.
5. Support protocols for BMW diagnosis, including: ISO14230, ISO15765, IFH, DOIP, etc.
6. Cover a wide range of vehicles and support efficient and reliable diagnostic functionsand a variety of special functions.
7. Ensure communication security and can encrypt communication data to ensure device and vehicle safety.
GODIAG V600 Update Schedule:
1. Plan to add authorization of Benz, Land Rover, Jaguar, CAN-FD, Toyota, VW, Audi (ODIS software)
2. Dedicated Android APP is under development, it will support both Ethernet and WiFi communication.
Support OEM professional diagnostic function of all For BMW series:
1 series: 1'_E81/E81/E87/E88,1'_F20/F21
2 series: 2'_F22/F23,2'_F45/F46,2'_F87
3 series: 3'_E46,3'_E90/E91/E92/E93, 3'_F30/F31/F34/F35,3'_F80
4 series: 4'_F32/F33/F36,4'_F82/F83
5 series: 5'_E39,5'_E60/E61,5'_GT(F07), 5'_F10/F11/F18
6 series: 6'_E63/E64,6'_F06/F12/F13
7 series: 7'_E38,7'_E65/E66,7'_F01/F02/F03/F04, 7'_G11/G12
X series: X1_E84,X1_F48/F49,X3_E83,X5_E53,X5_70,X6_E71,
X6_E72,X3_F25,X5_F15/F85,X6_F16/F86,X4_F26
Z series: Z4_E85/E86,Z4_E89
I series: I'_I01/I02
MINI: MINI_R50/R52/R53, MINI_R55/R56/R57/R58/R59/R60, MINI_F55/F56
