pork-n-beanz
the car is a mazda miata with itbs i cant seem to find anyone one who knows how to tune my car properly using alpha n can anyone help thanks
You need to run vacuum tubing from the sensor to the engine intake manifold. You can use a nipple on the throttle body that has full-time engine vacuum (i.e. NOT ported vacuum). The source you choose should have a high vacuum at idle, if it does not, it is a ported source, and you need to hook your vacuum line somewhere else (either another nipple on the throttle body, or one connected directly to the intake manifold).
The car is very hard to tune indeed. It's possible to tune it in speed density but it'll run like crap and stumble as soon as you give it gas or floor it, map change is too slow compared to TPS change and small map changes require lots of fuel change, typical for high comp ITB race engines.
To be continued...
