VCI for BMW inpa, ESYS, ISTA, etc.. BETTER THAN ICOM
diagnostic
Brand new, never registered, still in the box, GoDiag V600-BM OBD2 bmw VCI. Connectivity via wifi, Bluetooth, Ethernet or USB. selling for $225
GODIAG V600-BM Diagnostic and Programming Tool for BMW Support DOIP K-Line CAN FD
Highlights to get GODIAG V600-BM:
1. Can work with Original BMW Software, have same diagnostic functions with ICOM A2.
2. Support Latest Protocol like DOIP K-Line CAN-FD, can work for latest BMW Car Models.
3. Support WIFI & Lan Cable Connection,make communication more easier.
4. Support Vehicle Intelligent Diagnosis,ECU Coding, Programming and Special functions.
GODIAG V600 is a professional diagnostic & programming / coding tool for BMW, it will replace GT1, OPS, OPPS, ICOM, ICOM A2, ICOM A3, ICOM NEXT.
V600-BM CAN-FD J2534 can access to all systems of newest For BMW car models to quickly read / clear fault codes, read dynamic data stream, active test, activation, components replacement, ECU replacement and upgrading, personalized settings, ECU programming , retrofitting and upgrading car configuration, SCN Coding, transmission initialization, enable the hidden features etc.
GODIAG V600-BM Functions
1. Can perform vehicle intelligent diagnosis, all-system all-function fast diagnosis; can read & clear fault codes, read data stream, actuation test etc.
2. ECU programming and calibration. Fully compatible with official diagnostic software
3. Multi-task diagnosis: based on the efficient architecture design of diagnosis service software
4. Diagnostic feedback: support one-key upload the device logs. If you encounter exceptional vehicle and abnormal function, you are allowed to report the problem to the manufacturer, then the technicians will track and handle your problem.
GODIAG V600-BM Features
1. With the size of about 108 x 52 x 27 mm, the pocket device is more portable
2. Brand new industrial design, the shell is made of solid and stain-resistant material, it is more suitable for the automobile maintenance environment.
3. Support WiFi wireless connection, high-speed transmission, long-distance transmission, stable signal and strong anti-interference; WiFi can be set as STA or AP mode at the same time, making users work in comfortable indoor environment.
4. Support wired Ethernet connection,can freely switch between 2 modesWAN / LAN.
5. Support protocols for BMW diagnosis, including: ISO14230, ISO15765, IFH, DOIP, etc.
6. Cover a wide range of vehicles and support efficient and reliable diagnostic functionsand a variety of special functions.
7. Ensure communication security and can encrypt communication data to ensure device and vehicle safety.
GODIAG V600 Update Schedule:
1. Plan to add authorization of Benz, Land Rover, Jaguar, CAN-FD, Toyota, VW, Audi (ODIS software)
2. Dedicated Android APP is under development , it will support both Ethernet and WiFi communication.
GODIAG V600-BM Supported Software:
1.Comes with ISTA-D, ISTA-P, Tool32, For BMW Coding, ISPI, INPA, E-SYS, WINKFP, NCS-Expert Tool, and you can directly run them.
2.Compatible Protocol: J2534, CAN-FD, DOIP, D-CAN, ISO14230, ISO15765, IFH, K-line
