I have installed the rear coilovers
I took some pictures with the overfenders, still no alignment
front coilovers, exterior tirods, samco hoses, walbro gas pump
put some colors in the trunk
I installed the pump with new gas tank gasket, but I forgot to take pictures
I had to change the s13 inner tirods for the 300zx inner tirods in order so fit the SPL ones
How the engine bay looks like
Front coilovers installed
Starting to have some light !
Lights didn't close so I searched 'til I found this ... I tried with a silvia controller and it works well, but my pop ups just don't lift. Then I noticed that the controller from the 180 had 2 plugs and the silvia only one, so that might be the problem.
I got a type-x areo kit (Bumper and Side skirts)
Adjusted the rear ride height camber/toe/caster (still needs to be aligned professionally)
Test fitted the bumper
Bleaded the brakes
Snow arrived!
My daily 97 Volvo 850!
So this winter i needed to work on the car, so i searched and haven't found no place to store and still work on it at a reasonable price. I stored it at home, at first as you can see it was pretty bad getting around the car!
Made some room in the garage and received the last missing aero part :bow:
Pretty hard to explain what i did with the wiring so i made this paint drawing to explain
I made a hole and fitted/hidden the harness
Engine bay
Inside car
Wiring almost done (still looks like a headache)
Motor, still needs the piping's to be done in one piece and some black powder coat on some parts
S13 fuel filter, i installed it under the car but pictures were 2 dark, i will try again later
I am also working on a is300/altezza Ducktail Wing
